Cobia 24' rebuild project.
zuluwarrior
Re: Cobia 24' rebuild project.
Yeah the stringers and bulkheads will all be up off the hull minimum 1/4". Right now I'm just building a jigsaw puzzle of the components if you will. All final trim and fit will have the foam shims in place. There will be a drain tube under the tank. The plan is for the tank to rest on a platform inside the opening and be a sealed area. Drain tube will run under that. Even after deciding to pack up and just relax I had a cold one(beer) and the radio was playing in the background I break out the vise grips and started in on the bolts that where holding down the Helm seat bases. Let me say I tried this same tool before with no success, well it must have been a good beer cause I got both removed. Felt pretty good after that.:D
zuluwarrior
You sound like your making good progress. I know that grinding is a nasty job. Still got lots ahead of me as well.
zuluwarrior
Quick question, what is the name of the program you using to draw over the pictures and will it work on a mac?
Mikeopsycho
Big project! I'd like to tag along and see what I can learn.
The 1/4" foam for use under the bulkheads, etc., is that a rigid foam or weather stripping type of foam or does it even matter at all? Thanks.
zuluwarrior
I have a couple of pieces of the pink foam I salvaged from a packing shipment. It is about 2" thick so I'll just cut a bunch and use that. I knew it would come in handy.image.jpg
kcassells
You crack me up!! My flav o flav is Mr Bud. Been around the world 3x ...game back to Mr. Budweiser. LOL to you again. Crack dem nuts. Beer muscles argggg. I'm beat... sanded, soaped, mopped, pressure washed...found out the friggin boat is White under all that discolored, no maint., left to dry and rot boat. So happy. Now I can make a plan inregards to finishes/paints.
kcassells
Cool... lots of good things here to learn. Welcome abord and anyone else who wants to jump in please do.
kcassells
The program was basic...took the pic to paint to make the edits. Not the best but it works. I have a good other design program but that would tale me a long time to show off the stuff that is so simple to comprehend.
Gots me some whole 1/2 chickens smoking on the grill with some crazy cool quick thought onion butterflies.
kcassells
Everyday stuff from home deblow. Pink, 1/4". Cut little squares...spread out like every few feet. Paste them down with waht you like. Ie; resin, glue... then set wood, fill all gaps!!!!No air left or the same nightmare starts again.
kcassells
Here is what I knocked out today. I went a little of the grid by some others. I saved a portion of the side of the boat floor. Added an underside and also left scraps of " fiberglass" to set my new stringers in. I grinded, cleaned, soaped then used bleached to kill off the green stuff. I have to go.
Chickens cooking, wife up me butt and have to take my son to work. Good yaps to all!
zuluwarrior
Man you really got going, great progress!
kcassells
Beat.. cooked ate dinner... now I have to clean up the yard with all the pcs. I left lying around. Finally a Sunny couple of days!
Catch ya on the rebound...
kcassells
I'm slightly getting concerned now. You have the same Ryobi tools I use...others are alot better! Cold beer makes you work to fix it! And your start thread date is the same date as my Birthday.
Also the boats are similar.
............Welcomde to the Twilight Zone...do da do da, do da do da....
Life is great! Enjoy!
zuluwarrior
:D:eek: unplanned and unrehearsed man only in the boating world
kcassells
Major Ditto....I have to go wash this stuff off. All in all a great couple of days since the weather let me in to bite away at it. I needed the $$ but pushed off side jobs till next week to get a sense of completion.
TIRED. My little Girl looks great and I hear alot of the birds chirping there *** off outside. One in particular I never heard before. Climate change? Must be mating time now.
Spring has finally Sprung in Pa.! Boat...Garden, hmmm Boat...Garden...hmmmm ,...
kcassells
Hey shoot over some more pics of the boat, in, out, top sides so I can get the overall of her look.
Well, after you wake up you old coot, shoot over those pics you promised.
kcassells
Wow....Those last two pics shows off how much work you've done on the boat. Looks Great! Am I seeing the ocean in the second pic? Now I'm jealous. Just push the boat to the water and off you go.
kcassells
Here's a question. Does/Did your steering cables run under the boat, on the gunnel, or inside your gunnel? I'm trying to determine where I want to put mine and serviceability is my direction.
zuluwarrior
All the cables ran under the gunnel but I'm going to change this and cut some holes into the bulkheads and run a conduit from the helm to the transom and leave a spare fish tape in for future upgrades. I also only want 1(one) hose if any out of the transom just can't bear to cut to many holes in my pristine transom.
