Re: Cobra outdrive Installation HELP!!!
I just put my Cobra drive back on 2 days ago.I greased up the inside of bellows,put grease on the splines,coated the yokes in a light coating of grease,the o rings I sprayed with silicone spray lub so they would slip into gimbel bearing,if there is grease on the o rings it won't slide on well.Did you make sure your bell crank was at a 90 degree angle to face of transom plate,while in nuetral? Also did you make sure the shift arm on drive was in nuetral so the bell crank will slide into it?The next thing I did was put a floor jack under trailer axle so I could raise and lower the stern of boat to line up drive.Then mine just flew in.
