coil problem
Status
Not open for further replies.
snoski
boat ran great for an hour or so and died in the water. No spark from the coil. With the switch on there is 12v on the + side and 12v also on the - side of the coil. Is this correct? No spark to the distributor...
Don S
Re: coil problem
What are we working on?
Re: coil problem
Ayuh,....
Did you follow the disgnostic tree,..?? What did you find,..??..??
Don S
Re: coil problem
This thread is closed. See original thread on same problem.
Status
