Re: Coil wire 115 johnson
The part of the wire that goes into the coil should not be stripped. Just cut flat. If it is stripped it will not fit tight into the hole and will come loose on you.(I tried this at first--didn't work) As directed before make sure the pin is not bent. Also make sure that the center of the wire is centered over the pin and that you push the wire all the way down to the bottom of the hole. If it is off a little you will lose spark at WOT.(I have had this issue also). Read the thread I posted a link to. It explains all of my mistakes with assembling these coils and Fireman57 explains exactly how to assemble them correctly. Have patience with it and make sure it is assembled correctly. These coils are a pain. If it helps, I replaced three of them and I still have one that is giving me problems(no spark). On wednsday I took it apart and the wire was centered on the pin but the wire was not seated all the way down to the bottom of the hole. I can now get spark at idle. I have not had the chance to take it to the water and see if it does fine at WOT. Good luck and let us know how it turns out.
