Coil wire install
SeaRayboater95
Hey Guys and Gals, quick question. I am working on a 2012 Larsen with a 4.3 Mercruiser. Changing wires and plugs and the coil wire was glued in. Had to rip it out and left a bunch of that material in the coil. Was going to clean it out and the book says to apply some insulating material in there. Is this necessary, and if so what do i use.
Thanks,
Ken
nola mike
Thanks,
Ken
I would normally go with Dielectric grease in this case, but not sure what the manual specifies
SeaRayboater95
Mercruiser #18 Service Manual.
I usually use Dielectric grease as well. When I removed this wire from the coil, it was glued in there pretty good. I've never seen that before. figure that was still factory installation.
Thanks,
Ken
Fun Times
Mercury-Mercruiser insulating compound (notably OEM part 92-416691) is a specialized, grease-like silicone dielectric compound designed to seal, waterproof, and insulate electrical connections. It protects spark plug connections, electrical terminals, and ignition systems from moisture and corrosion, ensuring reliable engine operation
