Coil Wiring confirmation
kulle
Can someone confirm that on the 1993 Mercruiser 4.3L v6, the coil wire connections are:
" + " - terminal - both Purple wires
" - " - terminal both grey wires
should be.
wiring is standard [h=2]American Boat and Yacht Council Standards[/h]
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
kulle
Thanks- guess the coil isnt't my problem- the Primary resistance measured 1 OHM , the spec says between .6 and .8 I'm getting spark but doesnt seem very bright. Have intermittent starting issues, some day it starts on first turn others i have to crank it then it starts but runs rough....sitting in idle after about a min or so will stall out....i can start again but same scenario. I have voltages at all the right places, check neutral safety switch and it grounds when depressed...guess i have to go to mechanic.
NHGuy
Take a lesson that I relearned this spring. Brush all the wiring terminals and connections clean. Fixed up my 97 wiring.
