Coil
hugh777
If a coil is leaking is it "bad"? My coil on my 1990 7.4 VP is leaking an oil like substance from the center where the plug wire goes to.
6meter
Re: Coil
Junk. Will probably skip or miss under a load soon. Match the new one with the right resistance.
tschmidty
Re: Coil
Absolutely bad. It's not a huge deal but try to get one that is epoxy filled instead of oil if possible.
ENSIGN
Re: Coil
Just get the correct coil for your engine.It's cheaper than getting towed...
