The Force power
- Feb 3, 2019
- 2,350
So I swapped out choke solenoids( I have 3 spare)and no change. I checked the green wire(with a tester) from back of switch to the engine terminal and solenoid and it checked out fine with no breaks within. I then alligator clipped the green wire on selonoid and ground as trying to use the choke-registered 8.34 volts.The other day I did notice the choke sluggishly working as if a bad connection- So long story short; the electric choke is not being activated with key switch which is telling me to replace it. It is the original I believe
The 8.3 volts reading is that when energized coil ? or power supplied to coil?
If before the switch have 12 volts & after switch 12 volt but at end of wire on 8.3 with no load, looks to me the wire is nfg.
