jimmbo
- May 24, 2004
- 14,519
That white stuff is disgusting. I've been counting the days till spring since the end of August.
More throttle and more electric primer.
My snowblower with Tecumseh 4 stroke usually starts first pull.----Full throttle , choke full on and about 4 pushes of the rubber primer bladder.----Nothing to it when you understand how it works.
If you have low speed needles, set them richer, Make sure the float is set on the tolerance range that allows the highest fuel level, Drill little holes in the silencer to allow spraying fuel mix into carb throat. As I said earlier, I preferred the choke system, but you don't have that option. DO NOT succumb to 'Starting Fluid', that is a sure fire way to guarantee you doing another rebuild. Sounds like you wannabe prepared for the ice fishing trip.
my blower is only stubborn the first of the season and only once after that one pull all year,most likely crappy gas.have you tried gapping the plugs a little wider?because I trolled a ton with my 90 I did that and it seemd to have the added bonus of easier cold starting.standard gap was .030 and I went to .040.it wasn't something I dreamed up either it was an evinrude manual suggestion for heavy trolling.sorry I never read your build,is that really a 140 in hiding?
, there are 140 ponies under that 90 bonnet.![]()
One of the faster 90s on the lake I presume
1100 meters lower and denser slippery salt water, she will haul. You will need a prop change. I didn't consider towing thru the Coquihalla fun in any way shape or form, but I guess its easier than Hells Gate. I would check about BCs laws regarding towing weight limits without trailer brakes, in Alberta there aren't too many restrictions, but its pretty flat.
No needles to twiddle, and floats are set parallel. The carbs are '79 1-3/8" bodies that I drilled for the primer jets - took all the choke flappers off (destroyed most of the plate screws in the process of removal), so that's not an option.
From the sounds of it, my best method (should I ever need to repeat starting in low temperatures) would be to pop the hood, turn the primer to manual, pump the bulb a few times to cram some more go juice in, then start with max idle and constant primer actuation.
And no, no plans to use it for any ice fishing. For many reasons, not the least of which my fishing trips usually only go as far as my local fish shop.
Some steep grades between Hope and where the toll booths used to be.
I remember there used to be a Brake and Radiator shop just outside of Hope, I think he had a booming Business going. In 1986, the first time I drove the Coke, there were cars, trucks, and semis all along the shoulders, smoke just pouring off the brakes. Saw several of the Runaway lanes with tractor-trailers in them. Good news, the speed limit is 120, easy to attain heading for Hope
No need to remove the hood, just push the key in and squeeze the bulb, does the same thing.
