bruceb58
- Mar 5, 2006
- 30,620
Re: water
Re: water
Re: water
If you have half a tank of fuel that is 10% alcohol and add a non alcohol fuel to fill the tank, you will have a mixture that is 5%. If the previous alcohol was at its saturation point, why would it all of a sudden come out of solution when you didn't add more alcohol or more water?since the solubility of water goes up rapidly with increasing ethanol, pumping gasoline with less ethanol than is in your tank, when your tank gas is saturated with water, will precipitate an ethanol rich water phase in the bottom of the tank, fuel filters, etc...
