comp.test #'s on 93' 200 ocean pro
junior1113
numbers are left top to bottom and right top to bottom what do you think still looking good?? there higher than they were last year maybee guages were off 96 96 91 105 105 100 bottom cylinders are 5 psi lower than top two???
crb478
Re: comp.test #'s on 93' 200 ocean pro
not bad, each gauge reads a little different but usually consistently. You might try to do a decarb and see if you can bring the numbers up, but if it runs good after the decarb I would run it. Ideally you want over 100 psi and with in 10% of each other. You are close enough to that and a different gauge might reach it.
