jbjennings
- Jul 18, 2007
- 3,903
Re: Comparing OMC 9.9 or 9.5 to 15 (horsepower) 2 Stroke engines only
The weight of the motor is not the only thing to consider as far as stress on the transom. You also have to consider the torque on the transom and the leverage created by the prop being low and the connection to the boat being up high. I think a 15hp pushing a moose carcasse would pull the transom apart at the corners in a short time if you actually ran it at 3/4 to full throttle-----making the 15hp useless since you couldn't use it without ruining the boat. I agree, a 6-8hp would be better. I have an aluminum welding machine that I'd have to put on that boat! Still, 15hp is probably too much. I should have looked at your boat before. However, I'd still have the 15 over the 9.9.
JMO,
JBJ
JMO,
JBJ
