try spraying a little oil in to the cylinders and see if it make a big difference? as far as the numbers go not bad as far as i am concerned. have seen worse.
sounds pretty good so far inside of 10% difference does it run? if so id get it up to operating temp and test again let us know what you have then ... the rings in that cylinder may be a little stuck if the engines been sitting for very long
