- Jul 23, 2011
- 52,321
stock GM Vortec heads (both the 062 and 906) are listed as 64, measure about 65. not sure what the Summit head is.
Probably this head https://www.summitracing.com/parts/sum-151124stock GM Vortec heads (both the 062 and 906) are listed as 64, measure about 65. not sure what the Summit head is.
Im just saying you want basically a stock replacement head vs soemthing with port design made for automotive performance applications which tend to focus on higher rpm than a marine low rpm torque application. i would talk with what ever vendor you chose first about the application .Ahh ok , I did not realize there was a difference in heads between the marine and hot rod . I think i will just go with the 906 / 602 castings from rock auto then. The 151124 head from Summit is what I was considering. Rock Auto has the Engine Quest heads re bagged as Engine Tech.
its all the combination if parts cam, heads, intake, carb working together and correct for the application. Typical marine application is more akin to a truck, rv, trailer pulling application where torque is king. A boat is under constant load like these applications.I gathered that. I just did not think about the rpm and torque curves. But I will stick with stock replacements.
Thanks,
Carlos
