compression top 90lbs bottom 70lbs
G DANE
Re: compression top 90lbs bottom 70lbs
I would try the "let it sit overnight" method. the fluid has to work on the carbon, and leaving it in for a while is recommended. Besides, you have nothing to loose, but a lot to save. Be sure to run it all out of it after the decarb. remember it will get to the bearings etc. too.
sandollar1978
Thanks, I'll get a nother can and leave all night. :D
