Condensor question
MRS
I am going to do a complete tune up tomorrow was looking at the condenser that came in the kit it has a copper strip instead of a coated wire never use one like this, plus came with a sleeve I think should go over the copper strip. Kit is for a 86 4.3 prestolite set up Thanks for any help.
jerryjerry05
Just cover it with the sleeve.
I believe it's cheaper to make them this way.
I never liked it. Keep the older one, (just in case)
MRS
jerry, Thanks will do just looked kinda funny to me. Will update after tune up Thanks....
MRS
OK tune went good timing right on now on to the carb. If I remember right the vacuum break for the choke should hold vacuum when I put vacuum to it with a vacuum gun right it is not. Boat ran great before tune up but was time to do and I knew carb. needed some work cause trouble I was having last two times ran it would foul plugs when trying to troll or ideal to long.
Does the vacuum diaphragm only affect the choke going on or could it make the carb. run richer? Thanks once again for any help....
