Cone Clutch Shift Bravo II
GasCan II
Hello;
I have a 1997 5.7L LX with a Bravo II drive. The drive is very hard to shift. I have replaced the shift cable and the helm shifter also lubed everything.Also pulled the cover and cleaned the shift d-tent and applied new grease , and the drive still shifts hard. I have to push and pull the shifter very hard , other than the hard push and pull , it shifts into and out of gear good. Am I correct in thinking that the cone clutch is worn and in need of replacement ? I don't think this drive was ever worked on.
Thanks !
alldodge
Have you tried to shift it by disconnecting the lower shift cable from the shift plate and push/pull with a pair of pliers?
GasCan II
No , but I will this week when I go to the boat.
Thanks AllDodge !
GasCan II
AllDodge;
I disconnected the shift cable at the engine , and it wont move by hand . Than I put a screwdriver through the hole at the end and still no movement.
Tomorrow I will remove the drive and try the cable again.
Will let you know !
Thanks
alldodge
Sure hope its the lower shift cable, if not that it will the drive
GasCan II
AllDodge;
I took the drive off and no problem with the cable , shifter moves with no resistance with the drive off. Now the drive is going to the shop for a look see .
Thanks !
GasCan II
Also is there a shift assist /cut out switch on a 1997 5.7L carb.Bravo 2 ?
thanks
GasCan II
AllDodge;
At the shop we replaced the shift linkage in the drive and used silicone grease on the inner shift cable .
She shifts fine now ! Looks like it was a little crud and a little wear .
Thanks for your help !!
