tango13
- Mar 10, 2015
- 87
After a ton of research, I want to confirm my plan for my ignition upgrade before getting started.
On my 1977 Mercruiser "250hp" 350, Ill be doing plugs, cap, rotor, wires, Pertronix ignitor, and coil. Since the coil is externally resisted, I'm going with a new coil with a lower primary resistance (Flamethrower II - 0.6ohms primary). I'm doing this because I want to keep the external resistor wire, since I dont really like having wires taped off or cutting into the harness.. Sloppy! I think that should work, correct? That will get a total of 1.5 ohms at the coil, which I need. Then, I want to do the ignitor I kit. This is where it gets confusing. After reading all over the place, I find that people argue whether you MUST have a 12v source, or if you can run from the coil terminal with less voltage due to the resistor wire. Some people say pertronix units can work with lower voltage, some dont. Long ago, I installed a pertronix ignitor on my uncles '79 Mercruiser 228 (with the stock coil & resistor wire) and it worked fine.. That was before I knew anything about the resistance requirements.
Worst case sceneario, I run a new 12v wire from my key... I just didnt want it to come to that.
Can anyone confirm any of this?
