Confusing Torque Values for # 1 outdrive Bell Housing Hinge Pins
84EdH
I have read different torque values for the hinge pins on the bell housing for early pre-Alpha drives. I have seen 55ft-lb and 95ft-lb. I have a 1979 228 Mercruiser set up. The serial number on the back of the outdrive is gone. I am pretty sure it is a #1 drive
Have the earlier recco. torques changed through service bulletins, or are the earlier drives supposed to use the lower setting?
any help appreciated
dubs283
Re: Confusing Torque Values for # 1 outdrive Bell Housing Hinge Pins
i always torque alphas/mc-1's to 100 lb/ft
bravos to 150 lbs/ft
blue loctite on the threads
84EdH
thanks dubs, thats what I will do!
Don S
Here is from the Service manual for your outdrive (#4)
attachment.php
Here is a link to the #4 manual, at the end is all the service bulletins for the 1 drive.
http://www.4shared.com/document/wPl4tS8_/Service_Manual_04.html
