hello,
here is my problem. when I changed the oil pressure sensor I found a disconected cable right next to it. I connected it and engine started fine no problems. When I dropped the boat in the water, boat was doing ok until I got to the no wake zone. I tried to speed up and the rpms increased but the boat would not go any faster. I turned off the engine, disconnected the cable, turned the engine back on and everything was fine again.
Actual problem....
yesterday I was changing a switch and I noticed the previous owner had disconnected the dash alarm. I connected it and I got 2 beeps when I switched the ignition and 2 beeps thereafter every minute. So I read two beeps was a sensor and I remembered that cable I had connected and disconnected again due to that problem I had that day. I connected the cable again and the alarm does not sound anymore.
I am now afraid that when I throw the boat in the water again it will give me the same problem of engine reving but not moving any faster than idle speed
Any ideas what that could be.
5.0 mpi alpha one drive.
thanks,
Actual problem....
thanks,
