Re: Connected a loose clable and now when reving the engine boat does not go
u sure about that?
It is an oil injected engine.
u sure about that?
You almost have to wonder if it isn't a bigger issue like an oil pump ready to lay on its back with its feet in the air. I agree with NHGuy and go spend the money on diagnostics rather then $100 on a sensor you aren't even sure is bad. That or go buy a pressure gauge that can go where the sensor is and see what the pressure really is and then find out what it should be. If it's up to par, then I'd bet money the sensor is bad.
