- Apr 17, 2002
- 71,320
Re: Connecting water heater to engine ? Advice needed !
Ayuh,... My quote from the end of agallant80's thread,....
While puttin' a Tee in the block drain will work, it's only 1/4" pipe, where as the provided port just aft of the t-stat housin' on the intake manifold is 1/2" pipe, same as the return,...
'n some t-stat housin's have a spare port, or you can Tee off the temp switch/ sender, which is also 1/2",...
Ayuh,.... Somewhere on the Intake manifold, Before the T-stat should be a 1/2" pipe plug,....
That's the hot water feed....
Somewhere on the Circulatin' water pump(bolted to the front of the block) is another 1/2" pipe plug,...
That's the return...
