The alarm is going off though causing the engine to go into S.L.O.W mode after I am at wide open throttle for a while then slow down. The engine clunks, like it kicks in and out of gear and wont go past 2300 rpms.
If I turn her off and restart the alarm goes off and she goes full steam ahead. I installed two new temperture sensors that run to two new water temperature guages on my dash so I can monitor each head individually. They are not getting above 120 degrees on each side so I dont believe she is overheating. Do I need the sensors connected to run this engine properly?
I want to remove the sensors to test them but they are not coming out and I am afraid to pull to hard on the wires fearing I may pull them out of the sensor and be F'ed all together. Anybody have some good insight into how to get the temperature sensors out easily?
