Constant ringing noise from throttle when motor is running.
Kranjack20
So I now have another problem with my motor. It’s a 1998 Mercury tracker 40hp 2 stroke oil injected. I had it running on the muffs and it runs good. But randomly after a few minutes of running on the muffs a high pitch persistent ringing started coming from the throttle on the console. The ringing doesn’t change it’s just a constant ring like when you first turn the key on for your motor and then the ringing stops once it starts. I turned it off and then turned the key once without starting it and it made that ringing noise without the motor running. Btw before it made no ringing noise at all even with the key just turned before you start it. I can’t find any information about this online. The motor runs good, pees water good, has over a half tank of oil since its oil injected. The motor wasn’t overheating because it wasn’t running long. I could hold my hand against the cylinder head. There was fuses under the steering console and I pulled all of them out one by one with the ringing noise going but none of the pulled fuses stopped the noise. So I’m kinda lost right now. I just made a previous thread for a different issue and as some of you may know the alarm wasn’t going off in that video…included pictures of the fuses.
Texasmark
On larger engines the noise is a warning that either your internal oil system isn't working or your engine is over heating. On some engines the low oil is a pulsating signal whereby the over temp is a solid horn......if they have the pulsation module.
If you are on muffs and only have this problem when on them, you have inadequate water getting to the engine via the muffs. Go put the boat in the water and operate it and if it occurs there either you have clogs in your water passages, or you thermostat or higher RPM (on larger engines) pop-off valve isn't functioning allowing extra flow through the powerhead at the higher RPMs.
Kranjack20
But it continually pees water a solid stream so I don’t think it’s any of that. There’s blue smoke so it’s mixing the oil with the gas
matt167
Pee stream doesn’t ensure cooling. It ensures that the impeller is working. There is a thermostat, and cooling passages which can cause a warning horn overheat
Kranjack20
How can I figure out which alarm the ringing is for?
cyclops222
Evinrude had that same condition. Motor over heat sensor in the cylinder head was stuck in the overheat condition. I pulled the wire connector apart at the sensor. No more alarm. Replaced the overheat sensor. Still great.
Kranjack20
On a little 40hp it’s either overheat or a low oil alarm if it’s oil injected
So I ran it for a couple minutes. Blue smoke so it’s getting oil. It’s peeing water and the water is warmer than the water that went in so that tells me the water is circulating…. I don’t get it
Kranjack20
Anyone got an idea where the overheat sensor wires are? lol
Texasmark
On my 4 cylinder Mercs, the sensor is embedded in the rear cover plate (water jacket) on the rear of the block.....the plate that the spark plugs protrude through, held in place with one small screw. Wire is tan.
QBhoy
Hi. Outwith the chance of high temperature, I wouldn’t assume that the alarm isn’t for oil, just because it appears to be burning it with smoke. If your oil is low, it will alarm too.
Kranjack20
Hey so I just got around to messing with it and I took the oil sensor out for the oil tank and no more ringing alarm. Put it back in and ringing alarm started back up again. Oil tank is about half full. Definitely not low. Sensor Just went bad? How would I even replace something like this? Maybe it’s not even worth my time and it’s better just to leave the sensor out? I mean I don’t need a sensor to tell me when the tank is getting low on oil lol.
Texasmark
According to Faztbullet, when this problem occurs the oil level sense magnet has fallen off it's mounting and the tank thinks its empty and shorts out causing the alarm. He has posted repair procedures, one being cut the tank in half, replace the damaged parts and glue it back together........I balked at this, worrying that I wouldn't get it sealed properly if I had that problem, but if that is what it takes so be it. He ought to know if anybody does. There were some other answers from others but I don't remember what they were or from whom......shade tree or professional.
Kranjack20
Yeahhh I think I’ll just leave it out and call it a day. Lol.
