Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Hi there, would anyone know where i could find a mounting template for a commander 4000 control box. Bought one second hand to relpace my 3000 classic and it didn't come with a template.
It will probably fit the same cutout as the 3000, if not, a template can be obtained through a Merc dealer. All he has to do is order the installation instructions for you.
I used the boat-side plate of the control box to mark where the holes would be drilled. My holes didn't line up either so I ended up covering one of the old ones and will put some kind of a decorative stud through the other one that is showing. It was neat to mount the new box where I felt it was comfortable for me - much different from where it had been mounted.
I ended up putting a 1" cedar plate between the boat and the control box to give me a little more hand room so my knuckles don't rub on the side of the boat.
I also tilted the front end down slightly as this felt more comfortable for me - i.e. pushing the throttle forward going a bit downhill and pulling back going slightly uphill. I seem to get more balanced pull when pulling on a sloped up angle - especially if I'm standing up.
