Re: Convert 14' runabout into fishing boat for the SW FL flats
Now that I have a floor, I'll try a cardboard mockup of decks, bulkhd and seating I have in mind.....basically a 36" flush deck at stern with a small splashwell, then a lower bench seat with side console, then open floor area for portable cooler/seat, then 40" raised deck/platform about 6"-8" lower than bow deck(probably match bench seat hgt),& bow deck of 24". I would put a live well in forward raised platform and keep portable gas tank under bench seat...and battery astern of tank and bulkhead at bench seat back. Trolling mtr at bow deck with battery under raised platform....forward of live well.
For now I may just put my 10 hp Johnson tiller I have laying around....maybe put the 15 hp carb on it....once I finish completely I had in mind a new 25 or 30 ETec or Merc??? Probably do some shopping this coming winter/spring....if I don't get a yr end deal this fall? ....
I'm running out of time....it will be 49 deg here tonight....so I may only get a primer coat on the boat by time I head south (around 10/16) ....and then do finish paint at fl house. I'm hoping to get all the bulkheads, decks and finish fairing by end of this month!!!
Trailer needs new tires & wheel bearing, repair rollers and bunks and a quickie paint job too! It's the trailer that came with boat ....old painted steel relic....won't last long with salt water bathing.....I'll try to pick up an alum rig later in fl since I plan to keep the boat there mostly.
