convert 2005 5.0 GXI to 2012 5.7 GIC
highpowerdad
If I drop a new(er) 5.7GIC ~2012 in the place of an old(er) 5.0 GXI-E ~2005, what would I need to change. Boat is a 2005 Four winns 190 horizon
I know I would need to have a 14 pin to 10 pin adaptor for the electric, but is there anything that would need to change on the exhaust side, same or different Y-pipe, connector tubes? I noticed the riser and elbows are all one piece on the newer motor (with Cats). does that connect to the same location in the old Y-pipe as my existing motor or do I need a different Y-pipe?
Any other "gotchas" in converting from the 2005 motor to a 2012?
Thanks
Scott
Florida
alldodge
Have not done this kind of swap but not to sure using an adapter 14 to 10 pin would be all that is needed. The motor uses a CAN bus and most likely will need the VP EVC display and cabling
@muc
As for the exhaust, if it will connect to Y pipe there should be no issue
muc
"Retired" Association of Marine Technicians...
No idea without S/Ns.
Take the serial numbers from both engines and start comparing part numbers to Y pipes TSK and other points of connection.
Serial numbers will also be needed to determine wiring, controls and gauges.
