I have a 1958 Evinrude 18hp (15024) that I am converting to electric start. I ordered a flywheel, starter w/bracket and a solenoid. A couple of questions. The original flywheel (no ring gear) has an inspection hole on the top. The new one does not. My guess is that it may have been on an older model. It otherwise fits fine, but I have not tried to run it yet. Is this a problem? I am also looking for suggestions on where to mount the solenoid and a starter switch. Can I use the stop switch as a starter switch?
I would also like to understand how to bench check the solenoid. It has 2 large terminals that I understand are used inline for the positive connection between the battery and the starter. The two small terminals are labeled I and S. I tried applying + power to S and - connection to the mounting plate as ground. No relay clicking. I tried this with + to S and - to I and applying +/- to I and S directly. No joy. This suggests that the solenoid is bad. For all tests I also used an ohm meter to check continuity between the large terminals. The circuit remained open.
Thanks for your help.
