mr300z87
- Sep 15, 2010
- 698
With the water pump taken care of (see my other thread) It was time to start dealing with other maintenance and upgrades. One the items on my list was to upgrade the steering ram from a crusty, worn out older style to the new type which required removal of the exhaust elbow I decided that now is the time to replace the exhaust. I bought the boat in 2012 and it has been used in salt most its life before I got it, I have not idea how old they are. My plan is to convert to dry joint system as it just seem to be a much better designed system. I have all the parts to do this conversion and so far all look good. The picture shows it mocked up.
My engine serial # is in my signature file but my engine has hoses from the Thermostat housing going to both the bottom of the Manifold and into the elbow as shown here. I was told by as Merc dealer that with hoses top and bottom to use a restricted gasket and if only one hose to bottom manifold use open gasket. Mine has both so using a restricted gasket.
So my question is what side of the manifold does the restricted side of the gasket go? In the attached diagram it shows on the output side. Is this correct?
As always any info is greatly appreciated and have a great evening.
