Converting Ignition Switch
GoFastr
1995 Century CC 20 footer with a Yamaha 150 outboard. Boat was basically a hand over to me and had sat on a lift for about 4 years. It's in fairly decent shape but needing some work here and there. I've alreadyt syphoned the stale fuel from the tank. Also the ignition key is missing so I was gonna replace it with another off the shelf ignition switch.
The ignition in it now is a wiring harness type switch with a sealed backing in which 7 wires come out (2 BLK, 2 YEL, 1 RED, 1 BRWN, 1 WHT). The extra wires go to the adjacent warning buzzer, separate choke switch and kill switch. Then of course there's a wiring harness main connector and a set of other single connectors. First time I've encountered a switch like this.
So anyways, was wondering if anyone has experience swapping this particular setup to a standard three pole (I, B, S) ignition switch using the existing wiring cut at the switch itself? I'm assuming the twin yellow and black wires from the back of the switch are common connections inside the sealed part and would be wired together on the standard switch. But what would go to which pole?
Don S
Re: Converting Ignition Switch
Guessing you have a 2 stroke, the 3 pole switch will not work with outboards. But you can get aftermarket outboard switches that will work, and they have all the different terminals on it.
ignition switch - iboats
GoFastr
Oh okay didn't know there was a difference other than some have a push to choke ability. Anyway here's a pic of what was in there.
Capt Ken
Being Yamaha doesn't use BIA standard wiring colors, gonna be easy to mess up. Why not just buy the correct switch.
99yam40
Take it to a Yamaha shop, it should have numbers on it to get the proper key so you can just use what is there
