Converting Trailer Tires, 12" to 8"
HVSTRINE
Re: Converting Trailer Tires, 12" to 8"
I'm thinking I'd be looking for a different trailer.
jdsgrog
From those two pics I am gonna guess the trailer started life as nothing more than a trailer for a good size aluminum row boat with 9.9hp outboard.
Per the welded on angle iron (bow side of that 2x6) and the concrete re-inforcing rod tongue truss, the tongue has been lengthened quite a bit.
I'm in agreement. I don't think the trailer was factory made for the trihull. I personally think the trailer was modified to fit the boat. It looks like a trailer made for a 12-14 foot boat. as I said before, I have a gator trailer for my 14' runabout that sits about the same height as your boat does. But it's a tilt trailer, so the rear bunks lower about an inch when you pull a lever so you can roll the boat off the keel rollers in a shallow launch. I'm wondering if your trailer started off as a smaller boat tilt trailer and it was modified by one of the previous owners.
reelfishin
The problem is that he's dealing with a trihull, there's not many trailers made that will fit that boat well. The chances of finding an affordable used trailer in his weight class may be tough. I all but ended up custom rebuilding mine to make it work.
Mine was originally set up with strait axles under the springs, I built two axles and mounted them above the springs. I also have the option of going from 13" to 12" wheels if needed. The trailer sits pretty low after flipping the axles, which were made from 2x2" tubing with no camber.
I also ordered flatter springs, which gave me another 1.5" or so. Over all the boat went from sitting 33" above the pavement in tow to being about 22" off the ground. That made a huge difference at the ramp. I also added a longer tongue, I went from about 12" ahead of the bow to about 42" up front. Being a welded, painted trailer, I just cut out the old tongue and welded in a new one which was longer.
Keep in mind that those outer hulls will interfere with most fenders if he goes with a common curved cross member trailer and fenders can come really close to the hull sides if they are wide enough to clear and happen to end up next to the hull when loaded.
I found that on most trihull boats, a flat trailer is the best option overall, the lower you can make it all ride the better but it's not likely going to be as low as a V hull on a proper trailer.
Drop axles make for the best set up, along with high capacity smaller tires, but that usually means building or customizing your own set up. I did see one guy running a tandem axle trailer with 16.5" x 6.50 x 8" wheels and tires which were on a flat frame trailer with drop axles. It got the boat low enough where he did need to run with the motor fully tilted.
What make is that boat? Starcraft? Many of those older trihulls weren't that heavy in outboard form. My Capri 17 is light enough that I can lift the hull off the trailer by myself with little effort. They are light hulls if they're not water logged.
wingo
Hi Guys,
The Boat is a 1970 COBIA w/50hp Evinrude (its fantastic in the water, once I gets it in). Salt water for the most part, I fish the shore line. I like to target Sheepshead, and an occasional Spot Tail. I never go out far.
Stowed away are an electric motor and paddles, in case of:eek: .......... The boat ramp is about 12 miles from my house, drive about 40-45 mph when towing. Just replaced all the wheel bearings and I use the best grease NAPA had. (another tip I picked up from this site).
I may try to squeak out one more year using this setup before I get a newer boat/trailer. The old iron trailer has served it purpose and its life is near the end.
And to thinks I was considering putting smaller tires on, on a trailer thats smaller than the boat really needs.
Thanks for all the info and advice!
Now to find the thread, "Honey, I need a new boat because"
