Cooling Hose Cross Reference?
shout
Looking for some help, I have a 1999 Chaparral 2330 with a Mercruiser 300 HP 350 Magnum, 5.7L, Serial number 0L375277. I am looking for a replacement for the Thermostat Housing to Circulating Pump Hose, part number 32-861590A05. The original has the "easy drain" plug, which is expensive, seems to be out of stock at most sites, including this one, and is unnecessarily complicated. I can easily pull the hose to drain it, when needed. Does anyone have a part number for the replacement that does not have the "drain" feature?
Thanks for the help,
-- Shout
alldodge
Re: Cooling Hose Cross Reference?
-- Shout
Howdy, need to check the S/N, it comes out to be a 3.0L alpha 1
I'll be checking to see if I can find something in the mean time
Bt Doctur
shows about $42.00 I would suspect a hose for a gm 5.7 waterpump to therm housing would be the same. If not carried in stock here, try basic power
oem reg 32-33189 and with drain 32-861590A05
shout
You are correct, typo... here's the correct number - 0L376277 - thanks for the quick response!
alldodge
Found the item as low as $38 by googling 32-861590A05
shout
Thanks AllDodge, really looking for the "non drain" version, seems silly to overcomplicate a hose...
shout
So I guess I'm an idiot, looked for the past 2 nights, didn't find anything, posted this question, kept searching and found this item number, Sierra, and it's available on iboats.com - Part is # 18-71337.
Thanks for the quick responses, I am now going to go spend some money
-- Shout
shout
Thanks AllDodge, greatly appreciate the help!
