fish4boats
- Apr 26, 2016
- 71
I took pictures of everything I need help with and the parts so you can see them.
The boat started overheating all the sudden. It sat for about a year or so before I bought it. In putting it in the water the first time it got hot when trolling for long periods of time. It now gets hot almost right away. In pulling the top part of the water housing off the thermostat was laying inside in two pieces. I pulled it out and put the housing back together." I'm not sure if it will run without a thermostat" ?
After finding it still got hot I pulled everything apart. In doing so I found two thermostats in the risers that did not work by testing them in a pan of boiling hot water. They did nothing.
My questions.
1. What thermostat do I need ? Old says v142-21 k6
2. The thermostats in the risers. Which ones are they and do they need to be there?
3. Where can I find gaskets for all of these parts and can anyone find me the part numbers?
Thank you so much
My questions.
Thank you so much
