Older inline 6 GM 160hp seawater cooled:<br /><br />Suspect my block has rust build up in its cooling passages.  Since angioplasty is out of the question I was wondering if it is feasible to flush it by removing t'stat, running intake water from impeller overboard, plugging overboard hose from manifold into water intake at t'stat housing, filling system with some "stuff" (Iron-out, CLR, radiator flush..?) and water and running eng. just long enough to circulate "stuff" and water and letting it sit for X # of hours and then re-hooking everything up correctly and flushing it out.  Is this effective? What kind of "Stuff" would be best?<br /><br />Thanks
