Cooling system working?
kax2000
Should water be coming out here under normal operating temperature?
I didn?t see a drop when on muffs or on the lake.
Thanks for any help in advance.
Evinrude Model #55973
Re: Cooling system working?
Water should be spitting / misting out of there at idle.---If you were skiing behind the boat water would pour out of there.
boobie
Did you ever get an over heat horn ??
kax2000
No overheat horn.
I could touch the cylinder head while it was running and it didn't seem hot.
That is what makes me ask if water should be exiting the holes.
Faztbullet
Just a mist or few drops at idle, will really dump when poppet and t-stat open.....
boobie
Does it have a thermostat in it ??
kax2000
Yes.
That is interesting..the water was very cold.
The lakes around here had ice not long ago.
Service manual calls it a exhaust outlet not a water outlet.
It is the idle exhaust relief !----Should have some water misting / spraying out at idle !!
boobie
Have you checked the thermostat to see if it's working properly ??
emdsapmgr
A 1969 55 hp engine. They guys are correct. After starting and running for maybe a minute, the thermostat will open in the powerhead and a fine water mist will start to come out of the exhaust relief ports. That's a good sign.
