Correct way to prop 165hp straight 6 mercruiser?
Jerzyfine
What is the correct way to prop my 165hp straight 6 mercruiser to get maximum rpm out of it?
Re: Correct way to prop 165hp straight 6 mercruiser?
Ayuh,... Welcome Aboard,.... Ya use the Pitch that allows it to run Wot, at good trim, at the rated rpms,...
'bout 44/ 4600 rpms in yer case I believe,...
Fleetwin
That engine doesn't like a lot of RPM's but has plenty of torque.
Most I've seen run at about 4300 RPM's tops. The props have rounded blades that I call "elephant ears".
Jerzyfine
Right now I'm getting 30,000 RPM. The engine is a 1973.
jestor68
You select the prop size(pitch) that will allow the motor to operate within it's recommended WOT rpm range; which in your case is 3900-4300 rpm.
I believe you meant 3000 rpm; not 30,000 rpm; since your boat's tachometer doesn't read that high.
If you need to adjust pitch size, do so assuming that an inch of pitch change equates to about 150-200 rpm change.
If you need to increase your rpm, you go down in pitch.
You likely need to remove the prop to read the size stamped on the prop hub so you know where you're starting from.
steelespike
What size and type of boat?
We can help you better if you get us the prop size,and do a lightl load test run to get us the wot rpm and gps speed.
Do you trim up for maximum speed? Does the boat respond to up trim?
Is the prop in good shape?
Jerzyfine
It's a 18.5' Searay runabout. I'm getting 3000 rpm and average 25mph. She does respond when I trim with the side padles. The prop is in very good shape. I have to go to the dock and take the prop off to see the size. Btw I want to thank you all for your help I really appreciate it.
steelespike
Is your boat a "Stringer"the outdrive doesn't have trim? I believe you can fine tune the setup.
And I guess the tabs will help some.
Jerzyfine
Not a stinger and its a I/O motor.
steelespike
So do you trim up for the best speed?
What are the "side paddles" you speak of?
If you have trim tabs your best speed will likely be with the tabs fully released.
We need your prop size.
