Hey all,
I am working on a 1977 70HP Evinrude... The motor runs ok, (needs carbs overhauled, some wiring updating, impeller, shift shaft seal, etc.).
But my concern is, the mid section (and lower unit in particular) have some pretty heavy corrosion on them...
I am wanting to know if I sand blast it, re-zinc chromate and paint, if you think this well present any problems as far as integrity... or over the long haul...
For the most part, they are only surface pock marks maybe 1/32 to 1/16 inch deep... but on the lower unit gear housing part there are some that are pretty bad... possibly even up to 1/8" deep...
I've never had a motor that was corroded this bad, so I don't really know if this will be a big problem or not...
Before I sink any money into getting it up to snuff, I wanted your input on the casing corrosion.
Lower unit (worse part):
Overview of mid/lower unit:
and a close up view of where i took a little sandpaper to some of the pock marks:
Thanks in advance for your feedback!
Num
Num
