Corsa exhaust smell
gapple12
On my 246 Chaparral with 6.2, I have the Corsa exhaust coming out the side operated by switch. When I turn it on and Im at idle or just in gear, the exhaust smell is present, but only when Corsa is turned on. Is this normal ?
if you have a fuel smell, then you may want to look at your motor.
and yes, if your motor is running rich or not firing a cylinder, when you have the exhaust diverted vs running under water, you will smell it.
gapple12
I would say exhaust smell, not fuel smell. I dont smell it under the hatch, just out Corsa. I corrected my first post.
Ayuh,.... It depends on which way the wind is blowin',.....
Ayuh,.... I can't smell it, so I donno,.....
If it smells like gas, it's probably runnin' rich,....
But, Ya, open exhaust above the waterline is gonna Smell alot more than exhaust dumped underwater,....
