I have a 1996 Force 120HP that is running about 4200-4400 RPMs WOT with the same prop that it used to run 5250+ with. I have had a very reputable shop check the motor and they said it is running great like it should. They checked compression, carbs, reeds, cylinder dropping, fuel system. It ran the proper RPMs on the dyno as well.
Could for some reason there be a vacuum leak while the boat was underway that might cause an RPM drop? I don't know if that would affect it at all anyway.
I suppose it might be waterlogged, but I really don't think it is. I am planning to take it and weigh it at a truck stop soon.
Thanks for any help you can give me.
