fireman57
- Aug 24, 2004
- 3,811
Re: could this issue be the fuel pump
Sounds like a plan. I think you did get this engine hotter than it should have been. If you had one plug that was clean and the others were tan that indicated water, usually from overheating. Make sure when you change the impeller on the water pump that you find all the splines if any or missing. If you don't have them all some of the broken pieces can lodge in a water passage and restrict your flow even with a new pump. You will need to find them. That would require taking the head off anyway to check them there. Hopefully you won't have to take the exhaust side off too. If you found the threads on putting a telltale on this engine it is a great time to do it while you have the head off. You will be able to see how far you actually go through the top to install the nipple you will screw into it.
