crack near water pump
Frankiea87
hey guys this is a 1987 mercrusier alpha one drive.. i removed the waterpump this week and in the process of prying the old one out i had the screw driver between the plastic of the pump and the (metal?) of the drive and it cracked a little bit.. not much i would say about a 1/8 of a inch deep by 1/4 in long.. i was wondering if this is going to be a problem with sealing the water pump housing.. should this be welded back? or not a problem? i know theres a bunch of gaskets for the water pump so anyone have any suggestions? attached are a few pics . not the best but hopefully you can make it out. thanks guys
Frankiea87
Re: crack near water pump
one more pic...
Bt Doctur
That is the suction side of the pump and if not properly sealed will allow exaust gas to be sucked into the pump and create a hi speed overheat condition.
Frankiea87
so what do u think? a welding job? or need new lower unit?
Bt Doctur
From what I can see ,there is considerable corrosion in the gasket area now but the picture quality needs inprovement. Might try photobucket.com. It`s free.
Frankiea87
yea theres a lot of corrosion... .so what do u think? need new drive? or can i sand it all down and paint it? or any options? can i weld that crack?
Ayuh,... I doubt it's even Weldable, being such a small thin spot...And the corrosion factor...
You might try building it up with an epoxy putty...
zbnutcase
I'm with Bond-o on that one, Marine-Tex would work better with that much corrosion. 'nutcase
Frankiea87
hey guys i brought it to the marine shop around here and guy told me to use epoxy also... just tried it and it drys in about 5 minutes... i came back about 20 minutes later and its hard as a rock... im just going to sand it down a little to make it smooth and install the water pump ..ill post pics... thanks for all your responses
Gary H NC
JB Weld would have done a good job on that.Much stronger than regular epoxy.
As long as it seals it should be good to go....
