Cracked mercury powerhead
Deus_Vult
Hi guys, I'm new to the forum, although I have lurked here for awhile.
Basically, I have been repairing and rebuilding the powerhead on my 1967 Mercury 500 Thunderbolt due to an unrelated issue. While doing this, I noticed that there is a 1.25 inch crack running along the outside cylinder wall of the #3 cylinder. Thankfully, there seems to be no damage done to the inside cylinder wall, and the crack seems to stop at the seem between the two (outside cylinder wall and inside cylinder wall). You'll notice in the pictures that there is a large roundish mark close to the end of the crack; this is from a power drill that I was using to remove a broken screw, and the the drill splipped and hit the powerhead; I'm not sure if this is what caused the crack or not, but I feel like I remember the crack being there before.
Anyways, I'm wondering if there's any way to fix this? I did some research and found that TIG welding can be used on engine blocks when they're cracked, as well as metal stitching, and I even saw JB-Weld used by some people. I guess the reason I'm posting this is because I want to see what you guys think is the best option for me, given the location of the crack as well as the size, as I know there are people on this forum that are far more knowledgeable than I am.
I was formulating a plan in my head that consisted of chasing the crack with a drill, then possibly filling it in with JB-Weld, or just using JB-Weld on it; however, I'm not sure if either of these would work, once again given the location of the crack and the size. I'd rather not replace the engine block because it is expensive, and I have already spent a lot of money on repairs for this motor. Any and all input is greatly appreciated.
Thanks
Chris1956
I have seen that type of crack in that area on motors that overheated. I am not sure what caused the "dimple" though.
Deus_Vult
Thanks for your input, overheating does seem like a very likely cause for the crack given the other problems the motor has been having. Any ideas on how to repair the crack?
The "dimple," as you call it, is the roundish mark I was talking about that was caused by the impact of the power drill.
If the cast iron cylinder is not cracked I would simply run the motor.----Welding may make things much worse !!!----Did you have pistons out of the cylinders , yes or no ?-----Any pictures of pistons / rings ?
Deus_Vult
Are you sure that just running the motor with the crack untreated won't make the crack expand/widen because of heat from the cylinder walls and the exhaust gases? Just making sure.
Yes I do have the pistons removed, here are some picutures of them with the rings on still. They seem to be in good condition(?), besides the carbon on the heads.
Faztbullet
Just run it till it fails..eventually it will start ingesting water that is pulled around liner. Seen many a I6 do this.
Deus_Vult
Ok...do you think that JB-Weld would at least stop or slow the degrading process, or would it just melt due to heat from the cylinder walls and the exhaust? I guess what I'm wondering is would it help at all, or would it just cause more problems? I just don't like the thought that the motor would slowly be killing itself like that.
Thanks for the input.
Faztbullet
JB weld would melt...just drill a small hole at end of crack to stop it from speading. Motor is over 50+years and unless you have special or nostalgia reasons just run it.
