I have found out the hard way that the dowel pins that center the main bearings have been pushed down into the block. I can get new ones from a local parts house, but what is the best way to remove the old ones. Do I drill them out, can I heat the surrounding metal and somehow pull them out? Also while reading the manual about the connecting rods, it calls for a special fixture to install the rod caps. Is this just recommended or is it a must.
91 70hp. johnson outboard
