Crazy noise I cant figue out
CurrentObsession
okay
Finally got the diode and both engines coded out a 12
I don't see that on the sheet, what now?
alldodge
Code 12 means the ECM has no codes. This is good so its probably one of the switches. Either drive lube bottle, oil pressure or overheat. Take them one at a time and disconnect the wire.
Drive lube has 2 wires but only one needs to be removed.
Oil pressure has a single yellow wire (below distributor or near oil filter adapter Tee'd with oil pressure sender)
Overheat has a single Tan/Blue wire (on the thermostat housing)
