So this is not so much a question as a rant...
I have a 98 Lowe 16'10" bass boat that has small cubbys on each side right behind the driver and passenger seat.
When I got the boat I thought that they were coolers....but they are WAY to small to be coolers. They might hold 4-5 cans each. Anyone know what these are ment for? Or are they just storage compartments?
There is a drain in the bottom of each one but sadly water got under one and in the 95+ heat we've been having it bubbled the bottom of the plastic making the small compartment useless now.
So I'v cut the plastic out and dug into the foam a bit to try and make it at least a little bit bigger, now all I need to do is either find a plastic tub to install back in, or build a aluminum box to install back in.
