Re: cut & fit stringers-part 2
Kenbo, I assume by limber holes you mean drainage between the stringers? There are small notches at the lower corners of the stringers where they meet the transom, so any water that does get in will drain to the rear and into the central bilge.<br /><br />Hawkeye, what you see is what you get. The only bulkheads are between the two middle stringers, there isn't a need for any anywhere else.<br /><br />AlanR1, I am using 3/4 acx, You can use marine ply if your wallet doesn't object, and I do not do anything but cut and glass it into place. I use plenty of resin, mixed so that it it will cure at a rate that will let it soak into the wood, but not soak so much as to draw from the glass too much. By the time I am done, not a single piece of wood will be bare and exposed.
