Re: cylinder head leaking water
That's not really a head. It's just a water jacket cover. You can probably just clean it off real good down to the metal and JB Weld it. Make sure the water pump is working okay. Leaks around the sparkplug are uaually caused by warpage from overheating. If the motor survives the ordeal otherwise, replacing the gasket is usually enough, as well as rebuilding the water pump. It's possible that the crack is just a casting mark, but if you're sure it's a crack, try the JB Weld thing.
