xjdriver
- Sep 10, 2012
- 341
Re: Cylinders Low In PSI ? (HELP)
You could have been on tdc of the exhaust, intake, or compression stroke, you need to be on the compression stroke. You could rotate it over untill you feel a puff of air from the plug hole, then whatch the piston untill its at the top of the stroke. Youll have to do that for each cylinder. Just look up finding tdc on a chevy 350, im sure theres a more simplified way probly using a mark on the flywheel.
