- Apr 17, 2002
- 71,420
Ayuh,..... Does yer tester screw into the plug hole,..??Ok. Either I'm real dumb (strong possibility), or I'm real screwed.
0 compression/no movement on the guage on cylinder 1 or 3. I tried re-seating guage a little tighter... no change.
If so, bring that cylinder to TDC, compression, 'n pressurize with air, then listen for the sound,....
Through the intake, it'a an intake valve,.....
Through the exhaust, it's a burnt exhaust valve,.....
Through the oil fill, there's a hole in the piston,....
