Daily Driver
call back from ins company, they are re-running comps..... not holding my breath.
so the insurance company came up about a grand on the comps and settlement.... still totaling out the car.
So the admiral and I made a 4 hour drive to Jacksonville and picked up a 2008 Pontiac Solstice GXP for $5k needs a bit of maintenance and a few items addressed, however have a new daily whip.....
Old Ironmaker
The Solstice around these parts are generally an estrogen fueled vehicle but they are fun, hope you enjoy yours. I don't envy your daily commute, I don't know how people can do that. My nephew commutes from Toronto to Dubai. .
southkogs
Round headlights :cool: - I've always thought those cars would look cool with a vintage can-am style paint scheme.
My uncle had an older Solstice for quite a while and seemed to really like it. Congrats on the new ride.
Here is the CL ad https://jacksonville.craigslist.org/...558163631.html
here are some pics (from the CL ad)
many of the cars that we looked at, both Tammy and I thought....looks like a girls car..... one had pink highlights on the interior. it had been in 5 wrecks when we did the carfax.
this one has a nice burble to the exhaust, and any "bling" has been removed or blackened. new chin spoiler will be made to repair the missing section of the front bumper cover that has long since been taken out by a parking stop.
not sure I could drive from Toronto to Dubai.....LOL
something like this?
southkogs
Close enough! That's nice.
I was leaning more into the white with red and black accents in my head. Kinda' like this:
Or like this:
But that's just what was in my head. That "cobra" vibe is pretty slick too.
one step at a time..... boat gets color before the daily whip does.....
Maclin
Congrats!
update on the daily whip....... GM has a major recall on PPS sensors. the Solstice/Sky vehicles will all need new passenger seat cushions and passenger presence sensors. first took the car in may for the recall, parts just arrived (GM sourced from Lituania). car went in this morning.
back in may, had the dealer attempt to re-flash the TPMS/key fob module. 2008 GM vehicles have a defect... if the battery is disconnected for more than a few minutes, the key fob remote / TPMS module looses programming. so I replaced the module.... good news, they were able to program it..... now the key fobs work
A/C was non-functional...I could get the compressor to run if I jumped the relay. according to the dealer, needs a new BCM since its non-responsive.
so new BCM will be here on Monday. Dealer wanted to charge me list price. told them, I would only pay dealer transfer which is still $70 over what I can buy parts from GM parts direct (dealers in VA/NC/CA selling on-line) BCM and 2 hours of labor (diagnostics, R&R and programming) will be $482 plus tax
going to have air.....which is a good thing because I have been caught 4 times in pocket showers with the top down. so I can now have the top up during the rainy season (July thru October)
car has been averaging 30mpg, even with my heavy right foot. cant quite get 4 days of commute to a tank as would need to have another gallon of fuel capacity....... so may as well have fun for those three......
Plan is to get some DDM (Aftermarket tuner) charge pipes and I/C and get a mild tune. will push the HP from 240 crank to 295 at wheel while bumping mileage with a light foot by about 1/2 GPM
car gets a bit squirrelly on rain slicked roads, different tires will be looked at in about a year.
bit of update on the daily whip.....
developed a bit of a vibration over the last 200 miles
with 146k on the clock, most likely culprit was the timing chain
pulled the front end apart........ first thing..... the damper balance ring fell out
after much ado....... the daily whip is back running. i would like to find the engineer that designed that timing chain setup and those cheesy tensioners and strangle them with it.
southkogs
Not fun at all from the looks of it.
I've been driving a '92 Miata quite a bit lately (one of my FILs cars). It's got over 150k on it and runs like a top. Swapped out the convertible top earlier this year and it's been a fun driver. BUT ... now I'm playing with the idea of an old '63 Falcon he has around. I'd build it with a 260 and a C4, but I think it'd be an easy build.
I call it Scottspiration. More like inspiration and less like perspiration ;)
Guy around here has a red 63 Falcon convertible. He is running a stroked 302 at 347 cubes with a T5. It sounds fantastic, and s#!ts-n-gits
southkogs
Honestly, if it wasn't for the fact that I would have a running 260 right in front of me I'd probably opt to clean up a 180 and put it in there. There are a few dudes who've re-built 'em with duals but mostly just gotten them running well. The duals give you a little growl, but the 180 has enough power and isn't too hard on gas.
But the 260 is right there and it runs.
Update on daily whip.
Rear ended in December ( not my fault ) which netted me a complete new paint job. Got car back in march
In april, new timing chain components ( tensioner ) installed earlier failed, causing timing chain to flail about and eat everything in the front of the motor, filling up the engine with remnants of the glitter fairy.
So, new motor ordered.
At 153043 miles, new LNF bolted in. Have 450 miles on new motor
Update n daily whip.....
about 2 months ago, developed a P0341 code. which was cam shaft timing, bank 1 out of range.
motor had 3500 miles at the time.
I traced every wire from the connectors to the ECM to verify that it wasnt wiring related.
I swapped both cam actuator solenoids (one at a time) and determined it was not a cam solenoid (common ecotech issue)
I swapped both cam sensors one at a time and determined it was not a cam sensor.
pulled valve cover and swapped hydraulic tensioner because that could have been it.
after 3 weeks, took it to the dealer.....told the service manager on-duty all this, he seamed to be making notes
1.5 days later, skippy at the dealer says, the P0341 code is always a cam sensor. so I explained the troubleshooting that I had done, explained the bag of parts that were tried that was on the floor of the passenger foot well and asked him to verify that it was the sensor.
2 days later...... its not the sensor, not the wiring, not the ECM flash. potentially its a bad camshaft (highly unlikely) or a bad VVT sprocket.
they quoted $1200 in labor and $375 in parts to swap the VVT sprockets.
I paid the $85 diagnostic fee and said I would swap the VVT's in under 4 hours and under $150
order take off VVT sprockets from ZZP (ecotech tuner) for $99
order timing cover gasket and timing bolts from Summit racing for $30
this past weekend, was on pace to have the sprockets swapped in under 3 hours when one dropped bolt that managed to fall into a 1" x 2" oil return hole and drop past the windiage baffle into the sump turned the weekend into 2 days of swearing.
to pull the oil pan, the motor must come out of the car. you must then remove 20 bolts and use a razor knife, separate the bonded oil pan from the motor pain rail.
not relishing a 16-20 hour ordeal of pulling the motor, pulling the pan retrieving the bolt, etc
spent 2 hours looking on-line at images of the oil pan. there are two scalloped holes in the corners big enough to pass a bolt thru
so a trip to ACE hardware to buy neodymium magnets. 2 hours of attempting to walk a bolt up the inside wall of the oil pan to one of the scalloped openings to allow me to use my flexible magnet retriever tool to snag it thru the 1 x 2" opening...... success after what may have been 200 attempts
buttoned everything up and am driving the car as the truck transmission ate itself 30k miles after GM replaced the torque converter. good thing I argued with GM customer service on an extended warranty for the transmission. parts are on national back-order
there were 3 things wrong with the engine.
  • VVT sprocket was hyper-extending due to a manufacturing defect.
  • timing chain was 1 tooth off on the cam (could be from my swapping hydraulic tensioner, could be from the dealer digging in the engine
  • intake cam sensor worked, however the signal was marginal and at high RPM would not keep up
moral of the story....
  • man made things fail
  • new does not equal good
  • every 4 hour project is one misplaced/dropped/broken bolt away from a 2 day ordeal.
Now on to fixing other things.
Update on the daily driver..... last night on the way home, the ABS light comes on, the radio goes dead. the car says service ABS, Service ECS, service..... and then the lights get dim. Car up and died about 1.5 miles from the house
call home to get the wife and stepson to grab Zack's hyundai and some ratchet straps (tow cable was in the truck and that was getting the transmission rebuilt)
so, after 5 minutes on the side of the road, Zack pulls up, I crawl under the car and hook up an end of a ratchet strap. laying in a sand-spur bush. to top it off, there was road kill in the ditch I did not see and put my knee into the carcass.
tow the car home...... battery under 11 volts. put charger on it for 30 minutes then pull the battery to get it tested at Batteries Plus. Battery is just run down. Get car fired back up.
Zero output from the alternator I just had rebuilt.
pull the alternator and toss in the step sons car (had to drive that to work today). put charger on battery all night.
so off to the Starter/Alternator shop this morning. the new regulator had failed.
again, moral of the story, new doesnt equal good
on another note, got the truck back today as well.
